I have to extract this Beech trunk as its blocking a drainage ditch in the wood causing flooding. You can see the top on the floor under the leaning Conifer in the 1st Pic
After I remove all the branches, I need to cut the trunk to remove it as it is over waterlogged ground, 2nd Pic
My question is guys n gals, what size should I cut the trunk into as it will possibly go to a saw mill.
Cheers S.G.
Edited by Sussex Groundie
I guess you or the client will need to line up a sawmill who will take it - might be worth asking their preference before commiting - else if left till after cut at 8 foot every one would have taken it at 12.
but to answer your personally id cut at 8 (or less if chainsaw milling for my own use) just for ease of handling
Will check diameter next tuesday
Yes 8" or 12" would be ok thanks, got a 3 ton digger to help
Location Crawley
won't need a digger to help with those short lengths.
try 8' 12':lol:
Location Crawley
Closeish :biggrin:
If you need it milled, givus a ring. 7ft preferred:001_smile:
