I think you will find that it has a coating of some sort on the cover fibres, this may be a water based urathene, not sure what advantage it would give but does hold the rope together when splicing.
  • 4 years later...
Do you use the 10mm prusik rope with 11m climbing rope or do you have to go to a smaller diameter?
There is an 11m rope at work which I was going to try with the zigzag but I think 11.5mm is the smallest you can go with the zz so thought id give it a try with a prusik.
A blakes will work with same diameter hitch cord and rope, vt I find works better with smaller hitch cords. Bit of trial and error within guidelines is the best way really.
