I would have thought if it's for weather boarding it would be more than dry enough by the end of the summer particularly at 1/2"
That is quite a distance between stickers for such thin wood. Make sure they are completely in line with each other or you could have some quite bendy boards.
3 no stickers evenly spaced over the 2.1m length, say 400mm between them, reasonably on top of other
Is it likely to need more?
Easy enough to restack/resticker
cheers
mth
cheers
mth
400mm spacing sounds good but that should leave about six/seven stickers per length? Make sure there are stickers near the ends to stop twisting (some say it helps splitting too but I don't buy that).
Ah never did trust that particular bloody calculator!
Anyway no end stickers, and head-staggers or not, I devided by 5, not 4, for 3 stickers along a 2.1m length.
Oops
mth
  • 3 years later...
To revisit this post.
The cousin is looking to build a garden room, and since he does steel fabrication, we were in the notion of a galvanised steel frame, with insulation and ply sheeted internally, and I offered to cut weatherboarding for the outside.
I have a notion that I read somewhere that it did not really matter, or rather did not matter as much when conifer were felled?
Is this correct?
