  • Replies 22
should be good for stacking chip :biggrin:
anybody know were i can get a spec sheet for 1,
I'll ask our mechanic, he should be able to get hold of one or point you in the right direction.
I use a 2008 6.25 most days, good bit of kit, easy to drive and use. However trying to get at anything to service it is a pain. After a fuel filter change it usually objects by running rough when cold for a week or so.
Had been using an old JD4400 before that and still do occasionally, the Manitou is more instinctive to drive.
A
A
does yrs have that button on the joy stick,not what it does seem to slow it down wen preessed,
it had a slack throotle cable so wasnt ruuning on the correct revs ,so torque was slow ,some ajustment it went like the clappers :laugh1:
Johnny. Button on the joystick is to disengage power to the wheels so you can use the revs to power up the hydraulics. Bit like a quick clutch but you don't use it to change gears. If that makes sense.
cheers will have a dable with that tmro:biggrin:
had a dabble the other day easy wen you know how .:laugh1:
electric clutch as well ,weird ,must be a left hand drive thing :laugh1:
Manitou's are great machines, another good tip is to use the steering to side shift the forks or bucket when the machine is stationary and you are loading through a small gap. I miss driving them.
