I presume there's a stopper knot in the end? Would the teeth damage the bridge with constant pressure going on and off?
I will let you know after Saturday when i will use it on a dismantle....only tested it on a reccy tree....it is very smooth to adjust. I am full petzel these days. Harness....ZigZag and Zillon.
I will let you know after Saturday Elliot when i will use it on a dismantle....only tested it on a reccy tree....it is very smooth to adjust. I am full petzel these days. Harness....ZigZag and Zillon.
Today which is only 2nd proper working climb since setting it up and worked very nice especially when choggging the pole down as could get it really short and close in.
