Tip tie rigging with the x rigging rings.
Adam Bourne
  • Replies 47
Depends how big the stem is! Block for me on big wood EVERY time!
I'm talking stems of say 30 - 36 inch plus. Big blocks can be a faff go keep moving down and re-tieing, so I was thinking something like Rich's x rig with the whoppie could be useful and save a bit of time. I've never used these ring things so all I know is either swing checks for light stuff or large impact blocks for big chogging.
I would not have a problem ringging stems down of that size on them.
Surely you can glaze/burn out the rope using the x rings. I'm struggling to see what benefit they have over a pulley block
Have you had one in your hand?
They have a sort of ceramic feel! Extremely smooth
Can use with a pulley block as anchor point then craning point with a x ring which works well because it can be moved and carried much easier
Sent using Arbtalk Mobile App
