It's a generic Chinese made saw, lots of firms badge them and sell them at varying prices on ebay. Cheapest I've seen is £69.99. I bought one on ebay a couple of years ago to cut some off a Birch in the back garden and it does the job. The brake handle is a bit flimsy and the plastic is plasticky but it works. I didn't get a free bag and spare chains and mine has a 12" bar, it says 25:1 mix but it runs ok on Aspen or 40:1 with decent oil and it doesn't smoke as much :D Mine fired up out of the box and throttle stuck wide open but a fiddle with the linkage and the H & L screws soon had it running nicely but anyone of a nervous disposition may have panicked a bit. It's a Walbro carb, not looked for numbers but they are decent and spares are easy to get. The rear hanger is a bit flimsy held on with a self tapper I put a strop round the handle I wouldn't call it a professional tool by any stretch of the imagination but I've cut 8" branches with mine. It might be a cheap alternative to a 150T but it's never going to be a MS200 or a 540T replacement. It did surprise me when I went to it after it had been stood in the shed for months and it fired up second pull with a few pumps on the primer and idled away nicely. Mine's badged as a JTL, don't know what it stands for but it's like these.
Edited by peatff
Mine came with an Oregon 12" bar and Oregon 91VG chain (I believe is now 91PX) according to the handbook which is written in quite good Chinglish :D
I have a timber pro cs58 with the 20 inch bar cost£79 and is the best value for money I have ever had
Starts every time from cold within ten seconds and cuts as well as my Stihl and husqvarna
2 year guarantee
Plastic is cheap looking but ok
Nothing fancy but does the job
Interesting... im just a rough farmer but could really do with a top handle to tidy up some fruit trees - just find a normal saw abit cumbersum and not really very handy. Would this be worth a punt? For the cost id be looking at a well sh@gged 2nd hand stihl....
I have 4 of them ,same has MTD , you need 3 to keep one running !
That stupid choke lever breaks when you put saw away .
Don't rely on that strop eye hole either !
Constantly adjusting tick over .
Apart from that it does cut well ,starts well too .
Reason why I have 4 is dealer had them sent back for warranty work and customer's did not want them back .
For price they are ok .
Don't expect it too keep up with Stihl or Husky .
Ms 150 has more guts .
Ste
Ps ...ditch the chocolate low kick back chain for a Stihl chain ,dramatic change
Edited by IVECOKID
Mine arrived today. The first thing I noticed was the bar nose sprocket was quite difficult to turn. There appeared to be some burring around the nose area causing the sprocket to stick….. after cleaning it up , it was fine. Greased the nose sprocket , fuelled it up and filled up with chain oil. Starting was no problem…… although being used to a 261CM Stihl , I tend to forget about using choke !
It runs sweet as a nut. 25:1 mix.
Had the usual chain stretch occur after a while , as expected. No problem.
I used it to cut up some oak that I had sourced the previous day. No problem cutting through diameters using the full length of the bar. Plenty of cutting power, if you don't force it.
As I don't climb (yet ) , I can't provide any details in that respect , but it handled very well.
The one downside that niggled me , was the chain brake. i found that it was quite easy to keep knocking the handle and putting the brake on. But at least it works !
Good for £79.95
Use some decent oil and cut it down to 40:1 Maria. It cuts the smoke down and doesn't blow oil out of the exhaust.
