  • Replies 22
I had a sanderson 2.5 tonne machine about 12 years ago. I gave it an easy life but the chassis snapped in half which apparently was common so we spent several hours welding it up. A few months later the king pin on the rear axle snapped and the whole lot fell into a hedge tree. It was recovered and taken for scrap. I have had a jcb 525 for ten years and been good as gold.
Have been looking for a teleporter saw some Sandersons but they didn't compare well with the Manitou 626 that I ended up with.
Well worth waiting and keep looking! You don't have to spend a fortune to get a nice clean machine. Also may be better to find a machine with Perkins rather than the Ford engine, IMO!
finding a good owt snd hand is a lottery.found an aberlutes mint sanderson 725 on solo controls,BUT engine had issues,just watcting a few @' the mo.manitou,merlo,jcb,matbro
Does that have the Ford engine? They are prone to porous block!
Its only the early ford engines that were prone to going porous if its got the x block it will be ok.
Is telescopic handling a must? I got a old Coventry Climax 4x4 masted forklift for a third the price of an equivalent age/condition telehandler.
yes ,shifting chip, tractor wont push it high enuogh
Don't worry about the Ford engine; they are good starters and easy/cheap to fix and they just go on working even when badly worn out. Perkins wont do that.
Even the Ford crisscross block will give porous type problems if you don't keep the antifreeze/inhibitor in order; they can usually be sleeved which isn't too dear but even so blocks/short motors aren't too expensive.
As I have said elsewhere the Sanderson 625/725 telescopics were designed with Ford motor and the Perkins just doesn't fit very well and all but minor engine work will require removal which isn't easy.
