GreenMech make a 6 inch power feed to hang on the back of anything with cat 1 and over 25hp at shaft. You need 12 volts for the no stress device and hydraulic flow and return. Send a PM if you want more info.
We run a 4" timberwolf pto chipper off of a kubota compact. It comes on a low speed trailer, so it is easy to manouever. Very handy piece of kit and will genuinely take a clean piece of 4-5" wood. It is gravity fed however so you need to be aware enough to let go at the point the blades bite
MODEL: T300
Max diameter 80mm
Power requires min. 18hp tractor
In-feed height 850 mm
In-feed Dimensions (w x h) 440 x 300 mm
Recommended Retail Price (RRP) £ 3,895.00 plus vat
