Has anyone tried this?..... The tibloc
Petzl Charlet - Crampons, helmets & harnesses - UK • Tiso.com
I saw one in the shop the other day and seeing its simple one piece construction (it must cost buttons to cast) I imagined it would be a cheap alternative to a pantin. It works by using the crab itself to pinch the rope against the grips.
It ought to cost a fiver.....but sadly it doesn't.
Maybe Jonsie could do better??:thumbup1:
  • Replies 36
it does damage the rope. i have one. its sold as a rescue ascender. its nice and small so it can go on the harness unnoticed, but i guess the down side is it damages the rope....not really suitable for regular use. makes a nice key fob though :)
It looks exactly as the teeths in the ascender or the pantin, so there should be not more or less damage than that.
One could use a croll as well I think.
  • 1 year later...
very good Rich, great labour saving system, you should try it SRT if you get the chance, this guy is using a frogwalker set up on SRT -
[ame=http://www.youtube.com/watch?v=97KC7OhVZrY]YouTube - Frog Walker[/ame]
Edited by scotspine1
nice one rich. what sort of ascender are you using on your version?
I just had the usual VT, pantin on the right foot. The ascender below attached to a bungee and attached to the rope the slings length from boot.
Cheers Tim, only tried srt the once and it was Steve's setup. I may give it a go as i have a few ropes kicking about.
What do you recommend?
