Is red diesel as good quality as white, only reason I ask is cause some farmers I know say modern tractors don't like it and the sensitive engine management systems pick up all kind of faults when it's in use?
Its usually the other way round after the date that USLD was made mandatory across the board the older machines sometimes got a cob on about the lack of sulphur in the fuel ! also as said before Gas oil or Red diesel will be supplied and base stock fuel to a certain BS standard where as most if not all White Derv will have an additive package added at the refinery before delivery the higher the quality that is given by the retailer eg Shell V power will have a better additive package as opossed to supermarket fuel will be the same base stock but with fewer additives etc.
  • Replies 60
