My trusty TW125 is just not running right.
It had a dealer service last week and has sharp blades.
However, it's been a nightmare to use for the last 2 days, admittedly on stinking multi-topped conny.
The stress is kicking in constantly, even on 2" pieces.
On bigger pieces, but still only maybe 4" diameter bits of cord, the stress kicks in for about 20 seconds before further movement sometimes.
Any ideas?
  • Replies 49
I guess there are two options.
1The stress control is faulty
so try replacing all the relays, should be available at any motor factors.
Check the signal unit which checks the wheel speed hasn't got dirt around it.
Feck around with the buttons a bit.
2. The thing isn't chipping properly.
Check belts, manually look again at the blades/anvil.
I'd guess the stress control unit is on its way home.
Easy Fix but pricey.
I'll have a look tomorrow, but it had a full dealer service last week, so I think it's unlikely.
we had the same problem with ours after it was serviced and it was down to the fuel filter not being a genuine Honda filter it was a whatever one
(good technical term there) but it was one with the graduated pipes on it that need to be cut to the right size for the fuel pipe
so starving it of fuel which lowered the revs causing the stress thingy to kick in
The flywheel sensor on mine was at fault . Which caused similar problems to yours . The problem was that the sensor box had some water in it . After draining and drying then spraying with a quality wd40 all was good . I wonder if they powerwashed your machine after the service ?
Interesting about the fuel filter and the over zealous power washing. It's strange how many problems occur after a service. We assume some mechanical Jedi is on it whereas often it's a work experience kid.
