better still say you thought someone had a gun and you get
dogs helicopter and cops with gun
This is exactly what I'll be doing! If something of mine is stolen!!
  • Replies 34
Depends on the type of tracker. One wired in is easy to find, but I have a small magnetic one that is easily hidden. Even the manufacturer couldnt find it. You ring it and it txts you a google map link to its location. No yearly fees and just needs a sim card toppedup
Have you got further details about this tracker you have please. That sort of item is my kind of item.
Thanks jaime
i had one of those trackers once that the police can trace. Waste of money. the damn thing drained the machines battery after a couple of days, you couldnt tell if it was working, and it had to be fitted by them and they always drilled holes and ran cables where you wouldnt want them.
at least the one i use is transferrable to anything at anytime!
as already said, track it yourself and deal with it.
another top tip if you are being robbed. call the fire brigade and say your place is on fire. you get 6 burly guys to help then, not some pcso!!
Found that one on eBay before your reply make wise.. You can call it too and listen to conversations should you put it in your cab.. :laugh1:
think you top the SIM card up then you fit it to your trailer etc and you can txt it to receive a Google map of its location for the cost of 9p
Thats the cheaper one that does not have a long battery life. Get the 80-100 one.
How long will the battery last before taking them off and charging them up?
