Be sure to order the correct fuel line as there are two types, they differ in diameter where they fit into the tank.
Thanks ray, would you recommend any particular supplier?
  • Replies 55
L&S engineers
Seconded...........the gauze filter is fine, the fuel line is buggered, the saw will draw in air as it offers less resistance than drawing up petrol from the tank. A new one should sort it.
Ordered line, filter an a new plug from L&S tonight, will let you know the outcome when I get it done.
Thanks for the help guys, brilliant as usual!!
It got a new plug 3 years ago😂
Ok, I'll email them and cancel the plug!
👍 could of done with that saw yesterday lol I hit a ceramic plant pot covered in ivy the other day and I just can't get the chain sharp👎
Aye, chains don't cut through ceramics to well😆, you'll need to get yourself a stone cutter if you're going to destroy plant pots;)
Was just taken<< that stump down a bit to grind it out and knackered my only 18" chain:thumbdown: so I've ordered 3:biggrin: good luck with the saw bud👍
No luck, must have hit it bad to knacker chain!
026 will be fine I'm sure, it's a handy saw.
