Just been going over my previous tests to look at this. Just measured a sample of ash that was bang on 20% (not oven tested) so would come in at 750kg for a solid m3. Previously weighed a trailer load of ash logs mid summer and that was 320kg a loose cube presuming it was dryer than my sample I would suggest 340 kg for a m3 of loose ash logs at 20% (fits with other weigh ins). The conversion rate from stacked to lose is 1.42.
From all this I make it that you can get 1.55m3 of stacked logs per solid m3 of ash and 2.2 m3 of loose logs. based on the ash being at 20%
  • Replies 41
Woodwork's results = 2.2 loose m3 per solid m3
Finnish data = 2.5 loose m3 per solid m3
that's 12% variation between the two results, which is not that bad in terms of timber mensuration. A bit of replication and factors such as log length and average log diameter might yield more results.
