051 Clutch nut coming loose
Peat
The clutch nut on my stihl 051 keeps coming loose when I'm milling. I tighten it regularly but it has actually worn a hole right through the aluminium clutch cover! Although there was already wear here when I got the saw. There is often steel dust on the thread so its clearly doing damage here too. Should I replace the clutch, the nut or use loctite or something?
Cheers
Peat
On the 051/076 and even the old 020av the clutch screws on then a large washer to cover the Springs and keep the shoes on the clutch carrier, Followed By a nut.
The nut comes undone and the clutch can in effect fall from the carrier.
Not speaking from experience..... much :D
