Compact tractor and tipping trailer
keptenjim
A few pics of my Kubota shows the hydraulic configuration of the 3-pt linkage levelling system. 2 hydraulic pipes feed into a 2 way actuator to adjust the level of the right link.
My question is - couldn't these pipes be connected instead to a double spool valve since I don't require the levelling function of the 3 point linkage system. The levelling actuator of the right link is operated by electronic controls on a panel on the right mudguard - in conjunction with a sensor OR, it can simply be operated by a rocker switch under the seat
I appreciate any feedback from the hydraulics experts - Jim
  • Replies 22
Those two bolts where the pipes go in are almost certainly blanking bolts that you remove and fit pipes to for another service. Easy peasy.
Looks a nice clean tractor by the way :thumbup1:
Thanks Doobin - I figured that was probably the business end of the hydraulics system - just wanted to make sure
