We've been doing some zip lining recently, using a petzl tandem pulley which only fits <13mm rope. We've used an old climbing line, yale XTC, but wonder whether something stronger would be better and allow us to take bigger pieces. What do you use?
I'd be careful doing bigger pieces. You can build up amazing forces on a speedline if you make an error.
Personally I use 11mm static abseil line
Yeah I understand how the forces are multiplied at the anchor points, we have a groundie who does a lot of rope rescue with the fire brigade, where they regularly set up cable ways to traverse, lower and lift casualties. The tandem pulley limits me to 13mm rope so something stronger than XTC would obviously be better. Or I could use a bigger diameter line and a larger pulley I guess.
We're currently using 13mm XTC for the main zip line, and 10mm marlow control/retrieval line. We hang a 5m length of 14mm from the pulley with a prussik loop onto a crab and sling, to give us some height adjustment at the working end.
Edited by Perkins
