New Husquvarna 560xp
TIMON
Take the spark screen out. Keep the fins clean, keep the air filter clean. Oh and use the de comp button or you may break the starter.
Thanks, Brushcutter, Stubby
I will do.
I've heard that running the saw in is best done by reasonably high revs and plenty of breaks so as not to let the heat build up too much? Is that right?
I will do.
There are only 2 speeds . Flat stick or idle . So cut flat out but not for long periods until the rings have bedded in . Set auto tune as per the book .
