Imaginary Brushwood harvester/ bundler?
cessna
  • Replies 24
Quality any good for biomass?
I know its a good chipper on normal sized wood but the reason I ask we have received a lot of rubbish chip from brash so wondered what the heizo was like chipping it.
You need to accept brash chip needs to be graded with the fines taken out. :001_huh:Fortunately we have a market for the fines in our briquette production.
Fines are not our and I suspect most other medium sized biomass users problem. The main problem is long twigs that block the sensor sight from sender to reciever and give a false "the auger is full signal" If this can be overcome we would be happy to take a large quantity of brash chip. We use around 3000 tons per year so a reasonable percentage of that could be accepted. The drier the better obviously which would be reflected in the price.
If its log twigs your worried about then get a heizohack. Never ever had a problem of twigs although I do use a G30 screen rather than a G50. As I say fines are a particular problem I have with a customer using a gasifier but they can be screened out. As for moisture content I like to achieve below 20% although for the briquettes it needs to below 12%.
