using a 880 up the tree
JosephD
  • Replies 34
used fair bit mostly for crane work, saves work on moving round the stem. always clip it to your system as mentioned before, defo the go. i find if you lock your arm you can start the cut not bad, can move around abit at the start. easier to use smaller saw but takes more time.
i would never climb up with a 88, thats way you are chogging down or crane. make sure you leave it running, starting if a pain in the tree.
Key is good work positioning fellas
