Dremel alternative.
IanW
Hi I have dremel and can't fault it it all depends on how much you are willing to spend and how long you want it to last???
Aldies<dremel and then theres boshe and all the rest in between.
Must admit i like the look of boshe rechargadle one as it runs of the same batteries as the drills.
Imo spend a bit more it lasts longer and your happier with the tool
All best
I killed my aged Dremel recently and bought a cheap Argos mains knockoff with a big box of tools, flexible extension etc. for about £25. Works almost as well, will quite obviously not last as long. Unless you know you're going to use it a lot, experimenting with a budget machine has something to recommend it. Then again, I have zero brand snobbery.
