A friend of mine has bought a MS 170 for domestic use, not what I would have chosen but he's done it so the picco micro chain blunts a bit quick, is there a better choice which will last a bit longer and is a straight swap ?
Partly depends on gauge of bar, as can be seen below. Have a look over at 'chainsawbars'.
10" bar: 39 DLs, 3/8", .043"
12" bar: 44 DLs, 3/8", .043" Stihl PMM3.
Oregon same as above but shorter cutters.
Oregon Multicut, 3/8", .050",
14 bar: 50DLs, 3/8", .050"
Oregon Multicut. Though how the 170 is going to run a 14" is a wonder.
Edited by TGB
Used to run a 171 for fencing and light domestic work, tried many chains and kept coming back to the stihl picco micro, just seemed to out perform all the alternatives.
Thanks, it's on a 14" bar. It looks like I'll just have to tell him to keep a couple of chains ready sharpened. ;) It does leave a nice fine finish but that's not really important on firewood although it might be desirable on fencing work.
Good point that, make sure its on the 1.1mm as a 14" bar is slow enough without the saw having to take a thicker kerf.
I use Stihl picco micro on a couple of wee saws and found it to be fine, perhaps it`s what he`s cutting, maybe the woods dirty ? cheers.
It's most likely the wood he's cutting as he finds it all over the place and chucks it in the back of the van. He'll learn to sharpen them quicker anyway :D
The Oregon Multicut isn't as fast cutting as the others. But will stay sharp for longer due to having three times the chrome on the top plate.
