Personal preference and all that but you can just put an extension between the hitchclimber/micro pulley and the bridge of your harness to achieve a the same thing. A short sling or something. When you have made your ascent just lanyard in and take out the extension. I actually do prefer to pull down and then pull slack through when using DDRT though.
Can you reach that if you need to descend quickly or if it's not grabbing? Great outside the box thinking but looks a tad dodgy to me bro..
In your 1st pictures I take it both cheeks of the pully are held by the clip, if so how can you detach your rope to re anchor when climbing?
Hitch climber on a orig system or just go full on and get a zigzag, check out some good threads on that on here.
sent while pretending to do something important on my mobile.
I don't use that system just a self tending idea. I have a zigzag. In the ideal situation you throwline in high so no need to change. Otherwise it a case of untying the clip every time. Then again would you need a self tending system in short assents with lots of readjustment?
Simply up yes. Anything to save the pull push of prussic or split tail climbing systems even if your only progressing 3ft something that tends easily can only be a energy saving thing.
As said before having a small pulley tending the slack has been around in 1 form or another for a long time, think I started doing something similar in 2000 ish but with a small prussic loop and tool clip holding the pulley but was never an efficient system due to get binding nature of the blakes hitch and prussic knot . Then came the vt, knut, etc which changed everything as they opened out when progressed so took a ot less effort to tend.
Good to know people are still thinking because without it we'd not progress but il be sticking to my zz till something better comes along.
Sent from my iPad using Arbtalk
all the self tending systems a re just made 100% better if using a pantin or similar. no slack generated, no elbow issues, using your leg muscles etc....
