Hey chaps
some of you know me, been carving a couple of years now. thought i was getting better at this saw-lark BUT im having real problems with my new carving bar. Got a Sugi Hara, lovely bar. has a tip radius a bit smaller than the stihl bar and is reputably far tougher. Has a nicer profile too so I was dead keen to get one.
Problem is, its just producing black oil. the tip-cut is terrible ...just disnt seem to like cutting close to the tip, feels like its blunt even when new, even when sharpened.
So what have i tried?
first i went slow and easy for 20 minutes or more, new bar, let it bed in. it was overheating a lot so i rested it then gave it anoter 20 minuets easy going. still black oil... i
well, tried it loose, tried it v lose, tried it a bit tighter (this was an attempt to stop the dam black oil)
no change
when i got home I figured that MAYBE 'cos the tip radius is a little smaller than the stihl bar (and im using stihl chains) i might have to grind the heels off a bit as it MIGHT be riding the heels. this kinda makes sense as i have to do it with toonie bars using stock chains so I took a sander to the chain and dropped teh back of each tooth off. looks better but not really had a chance to try it properly. tried a few plunge cuts to see and it was overheating again but we all know that plunge cuts with a dime bar is a good way to cause heat
anyway, Ill give it a try tomorrow and see if it solves the problem BUT can anyone think of anything else i can try? Woodfest is only a week and a bit away and so if i cant fix the problem soon im gonna have to buy another dam stihl bar
oh..and before we get into a stihl/cannon/cheese/whoever discussion (you know who you are!) im looking for advice here on what i can try..please dont just say 'should have got a cheese bar'
:thumbup:
I shall refrain from the comment you know I want to make and try and be helpful. Try morris lubricants chainsaw oil. Its like snot. If you put a bit on your finger then touch another finger against it you can pull them apart and there will be a strand streching between them I would think this would leave a good layeron your chain and bar.if nothing else the black should stick to your bar rather than splatter onto your log.
Hey chaps
no change
:thumbup:
I think I read on hear somewhere that the really small tip radius makes the back edge of the top plate rub . Could be that .....
I run the Sugi Hara 12" bar on my MS200 with a 14" Stihl RMS 1/4" carving chain 68 DL. Lube is standard Stihl set so my lube tank runs out just after fuel and I have noticed no blackness and my tip does not overheat.
Possible oil issue?
thanks for teh comments (and well doen tom)
It seems the problem was solved by takign the heals off the teeth as i described. the bar was running lovely today and no black oil at all. Wish i had read that stubby, had to figure it out myself. so much for teh scientists brain, it took me all day cursing at the dam thing before i figured it out
anyway, the story has a happy ending. carving finished and i will post pics when i get them sorted
if you are looking for a bar with a lovely fine tip (R7 i believe) you cant go wrong with one of these. its about mid way between a standard stihl an d the samuri bar BUT as far as i can figure its MUUUUUUUCH stronger than either
price wise its about the same as a cheese bar, i mean a stihl bar but remember to grind teh heels off :P
cheers
