Stihl ms150
ntrim
  • Replies 28
Having borrowed Robs recently and used a 540 im aiming for a 150.Im sure the 540 is a great saw but the weight difference is a winner...
You don't get the torque of a 540/201 but for the little cuts where the bigger saws become heavy after a few hours use the 150 is featherweight and easy to use all day!
Here are some pics, drill a pilot hole, then go 8 or 9mm, clean out any swarf, give it a tap on the floor then shake it to make sure it's clear, pop it on & try it out, if when it's hot it revs high you will want to open up the H screw a touch anti clock, if it bogs at all from tickover, same with the L screw. Never had to do this on the four that I have modded. You will find it pics up revs much faster, & has more go in the cut.
14448981041_2727bf0453_c.jpgDSCF0004 by geoff321, on Flickr
14265735080_1ded21cfb0_c.jpgDSCF0006 by geoff321, on Flickr
There's a Stihl MS 192 T on ebay at the moment and it says he has others for £350 collection only. How would they compare to the 150 or 201 T ?
Comparison? Mmmmm.
I'd say the 150 even modded is still a bit behind the 192 in the power ranks. The 192 is nearer the 201 in standard form, but a modded 192 will have better uptake and speed in the cut than a stock 201, more comparable to a 200. Never run a modded 201 myself.
All that said, although the 150 has it's limits, it's an excellent little thing, there's certainly a place for it if you do a deal of pruning.
The 192 is a different animal IMO. Sort of an all rounder when modded, nice and light for pruning yet will tackle a modest dismantle, only pushed into second place in the power stakes by the epic 200.
Only one real conclusion I can make is, if you can get hold of a 192, the 201 becomes a slightly pointless saw, especially given that if you don't have a good 200, there's the next best thing,,,,,,,, a 540.
Cheers Geoff, I was in looking at them today, I usually climb with a ms 170, I couldn't believe how much lighter it was, me thinks i'll be going back to a top handle :-)
I doubt you will regret it, once sorted it is a lovely little saw.
With that much crap in there, that must be Spike's. :biggrin:
