Talked to guy who bought chinese tractor at half price of massey
Said dealer in essex was total wa***r
Contacted chinese manufacturer, spares in his hand in three days
He had nothing but praise for them
One of problems is importers buy on price
Then provide no back up
Used to be inundated with guys bringing in chinese motorbikes, they hadn't got a clue what they were doing ......when they had container of bikes they couldn't shift, support was first thing out of the window.....
The engine is totally wrecked as a result and have emailed launtop China to let them know about it. Got a response within an hour expressing their disappointment that their product has let me down and promised a further response within 48 hours.
  • Replies 23
When my honda petrol claps out I was going to fit a used 2 cyl watercooled Yanmar or similar running around 2000 rpm. Plenty of torque and economical. Its a shame the chinese stuff goes off like this a bit more quality control and they could make a decent machine.
look for a mod surplus store st mary bourne hirst and sons bound to have engines which will do log splitter and will go on and on. i have a ping pong engine on my pressure washer and after reading this post i think thats what happened to mine as oil coming out of main bearing shaft
Latest response from China. As much as they regret the failure of their engine they are worried that my log splitter was putting untested strain on the motor and this could of caused the malfunction. If my splitter was made to a world standard then they would have helped. WHAT A BLOODY INSULT!!!l
  • 3 weeks later...
Looks like the failure started at the gudgeon pin. If the piston shows no signs of seizure , how about over revving causing a faigue failure. Any small shiny speckled areas, appart from the obvious damage after failure? Of course it could just be top quality chinese metal
Hirst and sons have gone. Brian owns the bit with the weigh bridge and the other bit at bank top is cleared and shut. Brian may have stuff around but he is no hoarder its in and out or squashed.
Pi££es you off this sort of comment. A failed engine is really gold to the designers as it shows where their product needs improvement .....
Eg Land Rover took same attitude as above and their gearboxes are crap, mitsubishi gearbox layshafts used to fail but within a year or two they had made them stronger, they still occasionally broke so they made them even thicker - problem solved...
A sensible company would be desperate to understand why their engines failed,
You can take a horse to water........
I Agree whole heartedly I used to be in defect investigation and it is amazing what you can learn from the broken bits. They have certainly missed a trick here and lost some friends to boot.
Tried to set business up
When part failed under warranty get ups ( or similar ) to deliver new part and then ups failed part back to the department that designed it - So they get fastest way to improve their product
Ups can do this globally
You'd think they would jump at it ......
HA ha ha
IF they designed it and didn't just copy it.
The title says it all CHEAP. Buy cheap buy twice.
