RG Rayco
aspenarb
You grind metal with a stump grinder? :
No just a load of old wire in there, not enough to cause a problem but the lads that cut it down had had enough of it.:thumbdown:.
Something similar if not the same https://www.facebook.com/photo.php?v=678876322171060
Dont know , that thing looks lame. If its the same , had all the teeth in the right place and was on a rev A. that stump would have been gone in a minute ish and B you should not be able to see whats going on for grindings flying everywhere.
How do you set up an Ipad to take a vid, is there a gadget that holds it on a tripod or do you just prop them up and hope for the best.??
Bob
  • Replies 32
I timber using one of these during my time at Midland Tree Surgeons in the 90's. Heavy brute, towed behind a Hilux or Defender. Eat the largest stumps without problems! Loved car windscreens, golf balls & power cables in equal measure....
Sent from my iPad protected by bombproof Lifeproof Case
