Bows ( as in bows n arrows)
Blanks quite expensive
Β
That's because only a tiny percentage of yew is suitable unfortunately. Not much use for the OP. I believe it's primarily branch wood that's used for bows too, but stand to be corrected?
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
