Which winching rope?
  • Replies 21
I would have a few problems using polypropylene ropes.
1. They are horribly dynamic, i.e. they stretch a lot when loaded.
2. They weigh a lot and take up a lot of space (for a given strength).
3. Even if you choose a 22 mm diameter polypropylene rope, you will have a SWL of less than 950 kg and weigh 8.4 kg/20 m), given a safety factor of 5 (which, I believe is the norm in this type of situation). With my Tirfor TU16, I would need a 30 mm polypropylene rope.
I am currently using a 3/8" (10 mm) AMSTEEL-BLUE (DYNEEMA) which weighs next to nothing (1.1 kg/20 m) and takes up no room. It has an average breaking strength of 8,900 kg, giving a SWL of 1.780 kg (safety factor 5).
Edited by morten
I have the 20mm blue poly and I think it has a SWL of 5 ton. Have used with the tirfor tu16 with great success .winched a big beech to the bank of a moat no trouble. Like others have said no great disaster if you drop anything on it
Thanks. So 22mm polypropylene has a MBS of 46kn which is apparently 4.69 tons.
With a 5ton Tirfor I'd say that's fine.
It works for me and has done for a couple of decades.
I have used it to pull with tirfor, vehicle winch and vehicles up to tracked diggers.
If 4 ton wont pull it over its time for another plan.
But 14mm double braid is stronger than that.
Just retired my 16mm double esterlon due to age and plan on using that for pulling trees
mbs 7.5 kn
Just also remember most winches are rated 1.6 ton lift and 2.4 pull
Obviously depends which so have a look in manual
Only if you accept a safety factor of 1. But the industry practice is to use a safety factor of 5 for rigging
I would caution that polyprop cant stand the heat, I bought a 50m polyprop for giving the odd leaner a helping hand, ended up using it for trying to dislodge a hung tree and it melted where I had wrapped it round the tractor, sort of wish I had spent more now.
