I'm looking at buying a portable splitter that I can use in a number of locations and so ideally needs its own power supply and can be moved relatively easily.
The ones I've seen so far are from Fuelwood (woodline WL13) and Ryetec (Super Maxi DE Car)
Has anyone experienced using any of these?
Are there any others that I should look at?
Also looking into bench saws with own power as well, any advice welcome
Thank you
  • Replies 69
The only problem i found with the cone spliters is if you try to split the log in half straight away you run the risk of the cone jaming & having to cut the log out/off.
The way to split is to work from the outside in.
Most of the wood i cut is 'off farm' condition so to speak, and i found it hard getting a splitter to suit. The wood varies from 4 to 20 inch dia, and it can be rough enough, so i made one to run off my mini digger.
It pushes out over 17ton with a fixed cross head on it. It's nowhere near as fast as a processor, but i can fill and stack 2 builders bag an hour with it.
i find the upright petrol log splitters are very good ..
iv the honda 9hp model, its not as quick as the prosesser, but it takes alot of beating....it also splits any round wood,and is excellent on fuel too...:001_smile:
