Hi. What size file for our 281xp with 24 inch bar? Also What size chain when it's time to replace. Maybe a serial number for the oregan make, if poss. Thanks a lot.
Look it up on chainsawbars.co.uk
Oregon chisel 3/8 .058 84 drive links (73LPX084E)
or
Oregon semi chisel 3/8 .058 84 drive links (73DPX084E)
And as it is a 3/8" chain, you'll need a 5.5 mm (7/32") file
Edited by morten
or
Depends on make of chain
If it's stihl it's 5.2mm
Well, the OP specifically requested PN for Oregon, and that is what I referenced, so 5.5mm it is :sneaky2:
