I know that some people have tried it but wondered If it worked out well.
Β
We were at work chatting about it and it just got me thinking.
It would be an easy option if you already have a RW or ZZ.
Β
Β
Sent with my iPhone from me, to you!
Β
Β
Β
Β
Β
I've tried it and I prefer rw ZZ combo to just a ZZ on DRT
Β
Been a while since I demoed a ZZ but if I remember correctly you can't grab the tether to advance the whole system up (it just doesn't work) you have to grab the ZZ to advance the system, i.e ascending without a chest loop on. Nota. Big deal but struck me as different. Overall works well in my opinion,ImageUploadedByArbtalk1395820667.680407.jpg.1156ffda1f77388c54dc80f25393f596.jpg
Β
Been a while since I demoed a ZZ but if I remember correctly you can't grab the tether to advance the whole system up (it just doesn't work) you have to grab the ZZ to advance the system, i.e ascending without a chest loop on. Nota. Big deal but struck me as different. Overall works well in my opinion,[ATTACH]152213[/ATTACH]
Β
Β
Shouldn't the tether be connected to the top eye so the ZZ is aligned properly. It looks like it's under a lot of strain in that position
Β
Β
Maybe, I only tried it this way and it seem to work fine, I did look at where the links end up which are attached to the body when under load and it didn't look too bad.
( don't have the zigzag anymore otherwise would try it the other way :) )
Can understand your thinking though
Β
If the bottom of the tether is connected to the ZZ with a U-shaped shackle and the shackle pin is though the ZZ and tether, the shackle U could be used as the chest clip point.
Brilliant!
Β
That way everything would be neat and inline.
I'm pretty sure the ZZ is NOT rated for SRT.
Β
Doesn't mean I wouldn't use it with a RW mind.
Β
Β
Β
Shame as I thought they would have made something for srt use and ddrt.a bit of diversity. Do you think they won't because srt isn't fully recognised as a work positioning technique?
Β
Jake:thumbup1:
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
