  • Replies 37
on my greenmech that was doing the same , it was as Breezeblock said and was the hydrolic pump which after getting warm was not working at a high enough pressure. It only stopped working on large bits. Get a presure test done at a hydrolic place, all you need to tell them is the corect hydrolic working pressure, hydrolic place should better price than dealer
Go here and you ll get the bits for a new box for a fraction of the one tw want. I got mine supplied and fitted for £80. They gave me a number of a local guy. It was about 4 years ago when I had a tw.
WF Senate - Rexel UK
Cheers 👍
Keyboard warrior!..... Can't recallect the last time you showed up at any of the shows/Christmas get togethers that I've been to!:001_rolleyes:
I pritty much go to most of the shows my man! If I've time!
  • 3 weeks later...
Well today I rang tw tech support and they talked me through how to check All connections and relays near the h box, and my prob turned out to be a loose wire!! 👍
