I'm hopefully sorted with the mounts now, found a set of bar studs on eBay for £3, going to try the bar of my husky 576xp on it, later ImageUploadedByArbtalk1395770266.064952.jpg.3f6ec32871550bf948e99557efb3d765.jpg
Sent using Arbtalk Mobile App
  • Replies 65
Nice Ed - were they new? If so can you send the link?
Also just noticed in the pic your drive rim is pretty worn - make sure you replace it if you get a new bar!
:biggrin:
:biggrin:
Hi rob, yes they were new, they were replacement studs for Chinese saws aparently but does the perfectly, yes will do rob, did you say if the 576xp bar fitted, then the 395xp bar will? If yes I will put an order in on Monday (pay day)
thanks for the link ed i will get a set at that price
now that i have lathed down my studs i cant use the old sachs dolmar large bar mounts do you want to sell the original bar studs you have taken out
They've run out of studs but there's another on ebay selling for £4-95.
I'm hoping I haven't found a fly in the ointment - but with 8mm studs won't this give a K095 type mount and not a D009 mount?
K095 = 8mm slot
D009 = 9mm slot
So then if only a K095 mount max bar would be 24" - did you get a chance to try your 576 bar on the Makita Ed? It'll fit but is there a lot of play where it sits over the mounting bolts?
:001_smile:
i have just bought a set of those bar studs and have checked them for size and there is a bit of play on the D009 bar luckily the original studs i lathed them down so they just fitted into the bar mounts
thanks for that rob
but luckily the stihl bars will fit on the S2 bar mounts with a little alterations for the oil hole there is a dealer called
D S bennett that does the stihl bars readyfor makita/ dolmar saws
cheers shavey
thanks for that rob
cheers shavey
Thought so - but does the D009 bar still all line up ref oiler hole etc even though there is a bit of play?
There is abit of play but as far as I can see it all lines up, and the bar doesn't move with side casing on, ImageUploadedByArbtalk1396613921.711118.jpg.daabe1526d708e562cc4f64d2fe99e88.jpg
There is abit of play but as far as I can see it all lines up, and the bar doesn't move with side casing on, [ATTACH]152915[/ATTACH]
Good stuff - thanks for posting the pic Ed - :001_smile:
