Makita DCS9010 - what oregon mount?
Rob D
  • Replies 65
Hi rob, the two 12 mm round bits at the bottom, [ATTACH]151507[/ATTACH]
Sent using Arbtalk Mobile App
hello ed here are two pictures below of the 9010 after i lathed off the bar mount studs
if i had removed the the bar mounting plate i would have seen what was in behind i could have just moved the studs over to the d009 mounting i didnt realise there where two mounting options no need to lathe down the studs as there is a recess on the chassis of the saw :thumbup::thumbup:
Thank you buddy, il be playing with that tommorow :)
ImageUploadedByArbtalk1395582802.308730.jpg.47075bb585e005f89515ba40153c1053.jpg I still need to mill down the studs as they don't fit the recess and are too wide for it to, they would stil poke out, bloody saw, thought it was sorted for a min, Next thing is to find some one with a metal lathe,
[ATTACH]151948[/ATTACH] I still need to mill down the studs as they don't fit the recess and are too wide for it to, they would stil poke out, bloody saw, thought it was sorted for a min, Next thing is to find some one with a metal lathe,
why not buy 2 manifold studs, jobs a goodun?
