Hi - I'm looking for a large hydraulic winch to mount on the front of a 150hp tractor. The tractor doesn't have a front linkage or PTO. I saw (from a distance) an Environment Agency John Deere with exactly what I am looking for fitted - it had spade legs and looked really substantial. Does anyone know where to look for these? I am not concerned about fabricating a mount, and weight isn't an issue as the tractor needs ballasting at the front anyway. Any advice/makes to look for would be gratefully received! Cheers.
  • Replies 50
HI MONKEY just google winch and just before xmas i seen some very nice ones on the net 10ton pull they were EA thanks jon :thumbup:
Mod-sales do ex army stuff, sommat off the front of a "Mil-spec" loading shovel sounds about right.
rated at 10 tonne line capacity, which will probably pull nearer 20.
Should be able to source else-where cheaper than mod-sales mind.
m
  • 2 months later...
Hi mate have you fitted winch yet thanks Jon
Not yet Jon - I have found a bit of a monster from some big military vehicle but haven't had the time to get it yet. There will be a fair bit of head scratching in terms of fitting it too I reckon - once done I'll stick up some pics!
Hi mate what size is the winch thanks Jon
10.4 tonne Ulrich (apparently same company as Boughton). Hopefully it hasn't been sold to someone else!
HI MONKEY I've a 6.5ton one on my tractor on the front off the weight frame thanks jon :thumbup:
Sounds good - does it need a ground anchor or is the tractor heavy enough to hold it?
HI MONKEY tractor 5.5ton but we put loader forks in the ground or chain off the pick up hitch it a great winch i had my top mate do it easy job for him pipes cost £150 thanks jon :thumbup:
