A cheat that you can use for ultra ease of descent is to clip a karibiner somewhere below your lockjack...depending on what harness you use would depend where it clipped...perhaps to your legloop. Run the tail of the rope through this krab then use it to belay yourself.
Downside is, it's a cheat so you will actually hinder yourself from gaining the experience needed to master sole descent on the lockjack
  • Replies 20
That's a useful tip cheers pal, been 5 years climbing with a prussic, now I have a lockjack I'm well happy, don't no how I have done the jobs with out a lockjack lol.
Sent from my LT26i using Arbtalk mobile app
Hold the toggle between your first two fingers and wrap your other two fingers gently around your rope. This will give you more feel.
Rapid descents are for pimps and video 'heroes'. Why would you want to wear out your gear prematurely?!
Just give it time, you'd have the same issues if you'd bought an SJ.
So no, you shouldn't have bought an SJ, you should have bought a Hitch Hiker.
Haha!
Sent with my iPhone from me, to you!
Nothing more fun than descending from the tree at full speed :biggrin:
If you scream at the same time people think you fell out the tree :thumbup:
Haha!
Got to disagree with that, fast descending is often very useful for getting where you want to be, either out to the end of long lower limbs or getting over obstacles on the ground when you've finished.
Is there anyone that uses both the lj and sj, and if so can they give a comparison. Which they think is better
I have and use both and personally I prefer the sj but know loads of folk that prefer the lock jack.
I have leant them both out and most seem to end up going for the Lj
I also think if you tried the lock jack first you would prefer it and same with the sj
Very similar in a lot of ways IMO
