a) the tree isn't identically symmetrical?
b) the tree is taking IN oxygen instead of throwing it out?
c) its a bonsai and everything else is a scale model?
d) there's a party going on inside the crown and someone forgot the beers?
e) all of the above
f) none of the above
i dunno i give in :(
Hmmm, what's going on here?
Any ideas on the defect/problem? :D
I’d like to have a look under the subsiding branch to see the amount of reaction wood and creasing underneath. I wouldn’t put the picnic rug under it, that’s for sure!
Spot on John / Tee. Subtle it ain't! :D
That crown separation draws you in across the field to find a huge hazard beam failure in slo mo!
I love the estate this tree is on. A combination of ignorance and poverty keep all the trees managed with a light touch!
Fantastic liability but you always find something interesting!
Nice......
Did you make any recommendations to the estate managemen?
What would you do if it was your tree?
1.fence off the area to remove any targets
2.reduce the limb
3.remove the limb (causing a massive wound on the tree)
4.introduce bracing (although you could say its a bit late for that)
The fact that the gap is there would suggest it is moving faster than the tree can fill the gap with new shoots. Depending on when it happened of coarse.
