Osmo poly x best application
Woodworks
After all the recommends on here I have finally got a tin. Any special tips on application? I have used many oils over the years and most are similar. Put generous first coat leave for 10 mins or so and then wipe of excess repeat with thiner coat. Is this much the same?
I have two identical tables in the workshop that need finishing so planning a comparison with one being finished with my usual Liberon finishing oil and one with the Osmo. Pictures to follow in a few days.
look forward to the results,as I too have been convinced to buy a tin, and it aint cheap! last time I tried fiddes exterior oil, and it took an age to dry,wasnt inpressed, maybe it was too cold? i`m also very impatient:sneaky2:
