stihl 084
colwoodlandcare
I had one in exactly the same a few months back.
Hardest bit for you will be trying to obtain the oil drive part/cog. Stihl no longer sells or list them. I managed to get a new one off the chainsaw guy in Canada which was the assembley also with the metal fork for about £30 new old stock.
Cause I believe is down to the bearing collapsing. Yet again its a plastic cage bearing. You will prob find burnt plastic smeared inside the drum where the bearing goes.
Edited by wisecobandit
  • Replies 21
hello i have a question on my 084 when its ticking over there is a rattle clutch side i took of the sprocket rim bearing etc and the clutch is all loose and rattley it engages ok but it is a rusty colour i suppose it could be new clutch springs needed or a new clutch thanks andrew
New springs, if the plates are moving around. The centre boss doesn't wear, just breaks.
Yup as Rich says replace your clutch springs.
Oh Colwoodlandcare...
That 084 is the earlier model oil pump drive. When I was searching I did wander if it was possible to fit the later version drive. Theres a possibility they may interchange as the plastic cog that remains in the saw is the same part number as the later version which may or may not still be available. :sneaky2:
