Oxdale sawbench
RobRainford
Collected this from Sheffield yesterday. Had a days use today. Very good piece of kit. Lots more efficient than a saw. It's cut about 3 cube of firewood today ready for splitting which is a quarter of its value ish. Will be paid for in saved time very quickly.
When the new splitter arrives we will be properly set up.
Sent using Arbtalk Mobile App
Looks nice. I assume you pull the handle towards you to bring the blade into the wood, rather than taking the wood to the blade?
Can I ask what sort of price that was?
There's a yellow handle on the top you squeeze and tilt the log onto the blade. The red handle is to disengage drive if you needed to stop it quickly.
Re sawdust that was after a couple hours of cutting. The tractor was moved away from its cut pile so the logs weren't constantly being moved.
Cut 4 cube today I reckon at final count. That's with 2 lads not really rushing. Or pushing very hard at all.
The 4 way split on the posch splitter should breeze through all the material that comes off this machine.
