A 1600 TK, with the optional manual toe-boards. with a 27 HP KOHLER
or a
or a LT20MG25SDH3 woodmizer with the hydraulic gubbins and a25 HP Kohler
prices for either are within a couple % of other, assuming I got the import duty right at 2.2% for the TK.
Incl for carriage to N IRELAND
TK Pros, heavier built, hydraulic head motions, fractionally larger engine.
TK Cons, not "CE" compliant, not UK spec trailer, no hydraulic toe boards, no setworks.(not that I want them)
WM Pros, easily re-salable, Euro spec, full Euro compliant running gear, spares availability, hydraulic toe-boards, full metric setworks.
WM Cons, 12V head motions rather than hydraulic, cantilever design.
decisions decisions
Heart says TimberKing
Head says WoodMizer
oh er!
Rover,
how very perspective:001_tt2:
Clive at work allows i WILL, yet, TALK MYSELF INTO BUYING A SAWMILL:lol:
I am the worlds worst decision maker.
Cept in respect of
(i) Picking a wife/life partner
(ii) buying land
(iii) buying antique furniture
PS
this Sawmill indecision is ABSOLUTLY NOWT compared to my car buying decision making.
Mind I only do that every 12 to 15 years
regards,
Marcus
oops
thanks 7thdevil
heart might well win out yet.
specially iffen I kin drum up another purchaser to go 1/2ers on the transatlantic carriage.
Already planning the 600mm square wooden gate posts fabricated from 4 no 300mm square sections bolted together diagonally (with 16mm/20mm threaded rod), with all but the last 18" of each inner face chamfered off to form a cresote resovoir feeding into holes bored outwards into each quarter section.
marcus
see below, should sufficiently pickle the shitty Sitka in-situ.
Other gates swung from 2 salvaged ex Narrow Gauge railway field-gate posts, solid Mourne granite, about 12" square, by 8 feet long.
I had fun getting them set up on my own.
gaults gate posts.pdf
Edited by difflock
Not wishing to add to the complexity of your decision (OK, that may not be true) but have you seen the Oscar 230CE mill from Hudson and rejected it?
Alec
I have decided that iffen I am oblidged to use shitty Sitka.
I will "go large" to compensate for the finger thick growth rings.
To swing a set of "wrought iron" style gates, spanning a 6.0m gap.
Aiming for a 30-50 year lifespan.
Anyway downsized to 500mm to allow covering with a 600mm paving slab.
m
For some reason I cannot "warm" to the Hudson product.
Edited by difflock
