this is where im struggling, where I live has the worst signal around, plus being in a steel box does,nt help the signal.
have to leave my phone in the window to get a signal, but with this mifi thingy I can get a out door areal to a box in the boat.
all to complicated for meself!! but a friends works a treat.
Should be able to "pair" your ipad to the phone using the Bluetooth function on both. Check to make sure your Nokia has blue tooth, sit the phone next to the ipad and switch both on and then switch blue tooth on on both devices. If it's possible the Nokia should find the ipad and vice versa. Then you can use the Nokia wifi or 3G connection for your ipad. Just not sure if it works for anything other than an iPhone though.
Sent using Arbtalk Mobile App
It sounds to me that you need a mifi dongle.
You can put them a bit further away from you to get a signal, or even get the version with external aerial.
You can tether your ipad to your phone (use the internet off your phone while using your ipad) but usually your phone people want more money (unless on PAYG).
Sounds like the signal for your phone isn't good enough to be tethering inside where you live.
Something like this is what you need Broadband Internet Base Station 3G with 12dBi Antenna - 3G and Mifi Routers - 3G Broadband - The Wifi Shop - Wifi that Works!
