This large Lime tree snapped off half way up its stem in the recent strong winds. I was wondering whether you all thought that this was the possible work of Kretzschmaria deusta? I checked round the base of the tree and found no visible signs. However is this it half way up? Pics 1 and 2 are of the piece that came down. Your help would be appreciated.
Many thanks
Tom
Cheers guys, thought it was. Never knowingly seen it half way up a tree before. Is it common? Or will there have been signs on the ground and I have just missed them? Many thanks again.
Happy New Year!! Nearly!!!
Unusual to be at height in my experience, but we have come across the fruitbodies and associated decay up on the trunk.
I would of thought there would be evidence at the base of Kretzschmaria on this tree as well
Thats what foxed me. I'm not saying there were no signs. But I am familiar with the obvious fruiting bodies round the base ect.
I am heading back to look at the other trees in the area. Sadly this incident has put the wind up the estate owner as the tree failed in the middle of the village.
Hopefully there wont be any more problems, however she is already speaking of large reductions of the rest of the trees round this one.
Due to the recent winds I am sure trees will have unnecessary work carried out on them! Not good!
If you get the chance, take a trowel and have a little dig around the root crown/base of trunk, also give the trunk a tap with a soft faced nylon type hammer or wooden mallet, you should be able to 'hear' the decay if its there.
Sometimes find the fb's low down amongst the grass and soil.
I found it 10m up a beech a couple of years ago, no evidence at ground level, the decay was extensive too. Thats the only time i have seen it at hight too
Not unusual here for Kd to grow mid stem
But not common
Often initiated by tearout wounds or too big a pruning wound
Unrelated to basal conditions
This points to Need to use binocs when assessing
Maybe if you document the wounding/rot connection
And lack of same in neghbors you can spare them the chop
