Does any one run a 660 on a 42" bar
I run one with a 30" bar and it runs that with ease
Sometimes I need something bigger
I have a husky 3120 but only with a 30" bar
The price for a new bar for the husky is to much but can pick up a 42" one for the stihl for under £100 with chain
The stihl the better saw to use as the husky is a bit of a beast
Just stop it. Put a 42" bar on that 3120 where it belongs and be happy your 660 runs a 30" with ease.
Get a 42" Stihl bar and £6.50 Stihl - to - Husky bar mount adapter then you can run it on either saw ........:001_smile:
Stihl don't sell a 42" 660 mount bar in the uk. It will run a 42, preferably with skip chain, but if you've got a 3120 sat there you would be mad not to use that.
or just change the 2 bar studs
How can you do that ? you would have to push them into the oil tank , retrieve them each time ? Why not just use the simple adapter plate ? Piece of piss .... I agree he should buy a Husky bar and put it on the 3120 but he said he would rather use the Stihl .....
sorry my bad im going the other way husky bar on a stihl ,the studs just come out and replace with stud with no coller.what do you mean push into oil tank ?
The Husky studs are headed . The head fits in a location inside the oil tank and the plain section of the stud is a close fit in the hole . The way to remove them is to push them back into the oil tank and hook em out with long nosed pliers or a bit of welding rod . . The easiest way to run large mount stihl bars on large mount husky saws is with the Canon adapter plate . Check out the link I posted ....:001_smile:
