Vermeer sc372
Ty Korrigan
I have one!!!
They are a good machine, they are very reliable, reasonably fast and do not create much damage to peoples lawns (with dual wheels).
The cutter wheel drive is fine, some have reported lower gearbox failure but in 700 hours of use and abuse I have had no issues there. There are two reduction gearboxes the first is belt driven directly from the engine pulley, this gearbox is directly connected to the second gearbox by a drive shaft and the cutting head attached to this.
They do have some electrical connectors come loose i.e. fall off (mostly on the heater relay). With a better relay mounting connector they are fine.
I would recommend a 4x4 version, the two wheel drive do get stuck easily and they are a little top heavy so dual wheels are essential.
They are a good strong machine and I would happily have another. :)
I've used one quite a bit , pretty awsome machine..I love the blade and 4x4 comes in very handy , You can make good money if you have a lot of stumps , last time I hired it the engine had been changed to a tw kobota and it definitely speeded it up I know the engines are not renowned for there reliability though and the machine won't fit through gaps like a 252.
