Tree moving
kevinjohnsonmbe
Gnome
If you have ten trees to move around 20-25cm diameter at 20cm, to move with a 2.16 metre Tree Spade. We estimate that we can save clients 90% over purchasing in the same trees.
If is it just a single tree, we group you with other clients if we can to reduce the cost.
Have pm you with the costs!
Check out one of our largest Spades in action, much better music in my opinion and a 2nd generation design of Spade, on advantage of which is no towers which have to be pushed into the canopy.
a friend of mine used to work for a comp that moves trees in this way, not sure if there still doing it, they are called "waltons" and based at bruntingthorpe. they done trees on the royal estates, me mate even shook hands we Charlie boy.
whatever floats your boat!
