While we are talking about bars (espeshily you mr timber cutter dartmore) do you know of a 36" bar to fit a dcs9010? Can't seem to find one
I swapped out the bar mounting bolts for m8 studs and opened out out the oil holes on a oregan bar to suit, seems to work fine
  • Replies 94
thanks :001_smile:
Also, trying to work out what the similar husky model would be? eg;
Husky 550xpg = Dolmar 5105
Husky 560xpg = Dolmar 6100
and having trouble finding info to compare the specifications/ fuel use, chain speed, etc
....but definitely interested, especially if dolmars are more reliable. Don't care if they weigh a little more!
According to the German test facility KWF the torque and power specs are as follows.
Husqvarna 550
Max power 2.7 kW at 10500 rpm
Max torque 2.7 Nm at 7750 rpm
Dolmar 5105
Max power 2.9 kW at 10200 rpm
Max torque 3.2 Nm at 7000 rpm
In their manual Dolmar states lower/on the safe side numbers than tested by KWF. Max power 2.8 kW and 3.1 Nm.
Husqvarna 550
Dolmar 5105
Excellent info, thanks Wolter :001_smile:... now getting very serious about buying a dolmar instead of a husky. Did you come across any info on fuel consumption?
Excellent info, thanks Wolter :001_smile:... now getting very serious about buying a dolmar instead of a husky. Did you come across any info on fuel consumption?[quote
hello the 5105 is very good on fuel it has loads of power and revs out beautifully nice saw to use would recomend it too anyone
and also i have a new 7910 which is a beast and a contender in the 70-80cc it is a bit more juicy but it rips through wood like hell and would recomend to anybody
cheers
andrew
DOLMAR - PS-5105
http://www.dolmarpowerproducts.com/productcatalog/chain_saws_gasoline/ps-5105/PS-5105.pdf
and
DOLMAR - PS-6100
http://www.dolmarpowerproducts.com/productcatalog/chain_saws_gasoline/ps-6100/PS-6100.pdf
For starters the PS-6100 is at current exchange rates £305.25 plus shipping at roughly £80-100 and import duty at roughly £60-80 = worst case £485 inc. No vat reclaim tho on US import.
5105 was £286 but prices have actually gone down !!! :thumbup:
Imagine being in the US buying a saw in the 5105 class for less than £300; rip off britain!
cheers
andrew
Cheers, but could do with seeing some Dolmar 5105 & 6100 figures to compare with other manufacturers.
Today, for some strange reason the 6100 isn't shown on the dolmar website (pretty sure it was there yesterday), and the 550XP specs aren't available on the Husqvarna website either!
Are they reading this thread??!
tis here and as above
DOLMAR - Chain saws gasoline
I went on tinternet the other night searched for dolmar got the main site clicked on uk and was sent to a Mikita site?
Also is the Model: PS-7910 xD
The same as a 461? And prices??
Thank you
Dan
Edited by Dan Earp
