Not wishing to start a 'mine's bigger than yours' argument, but I can confirm that re-grinding a crosscut chain to ripping for an 88" bar is a good way to use up half a day.... Yes, for running long bars for milling you really need a grinder, to keep all the teeth the same length and angle.
Andrew - I would suggest you might as well go for a 36" mill. There is no down side really to the longer rails and you can use it with a 25" bar, but then if you ever do upgrade to a larger saw (which from your post sounds like it's eventually inevitable :001_smile:) you will already have the mill. The price difference is trivial.
Alec
88"!?! Even with a grinder, that's long and laborious! Imagine hand sharpening...
Sent using Arbtalk Mobile App
Alec
I suspect you're right Alec. I've had my eye on a burr oak tree on a neighbours land for a while which should have enough timber in it to make buying an MS660 worthwhile. So it probably is inevitable.....
Re upgrading from the small log mill to a bigger mill, I've a spare post and a spares bag of bolts, etc, so I'm proposing to just buy a bracing kit and a rail kit to construct the larger mill for about £100. I assume this would work?
Andrew
Plenty of big old stihls on eBay, from the 051 up to an 076, only one 070 though, and 2 contra's
They had just ended unfortunately, both from the same seller:
Stihl 070 chainsaw with 25" bar. | eBay
Sets the benchmark price quite nicely though - I would say that is reasonable, although if you hit really lucky you might get £50 off that :001_smile:
Alec
I'm based near Manchester Eddy.
Anyway based on the fact that I'm going to need
a saw
a mill
a ripping chain (assuming the saw doesn't come with one)
and a grinder/sharpener
I suspect it'll be a few months before I splash out... by which time it'll be snowing which will probably delay me even further :biggrin:
Is shropshire too far to travel for a saw? If not, I'll find out what big saws the bloke has left next weekend and let you know
